The brakes on my 94 camaro have gone stiff! I'm told it may be a bad power booster or something else. I'm going to keep checking, but in the mean time I need some advice and some help. What else could it be, and if I must replace the power booster, does anyone know where i can get a cheap one?
Power Brake Booster
Beore you do that, check an about 1" vacuum hose that connects to the booster. If it comes loose it will kill your power brakes, plug it back on and clamp it and it will work fine.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
Another thing you can try, us unhook the hose, and feel if you feel a vaccum(to see its hooked up fine on the other end)-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
