I was wondering when you know you need an alignment. I just put C5 Wheels on my car with 255/45ZR17 all around and the car drives straight. Although it does have a tendency to pull left or right sometimes. I also noticed that my steering is a lil dead and vague off-center but crisp when pushed. How can I correct this and tighten up the steering and does alignment and camber have anything to do with it?
Alignment???
changing the wheels do not call for a new alignment if your really picky like i am go to alignment shop they can center you stering wheel and if it drives straight most of the time it sounds like your ok. i wouldnt worry to much . watch your tire wear
[ March 11, 2003: Message edited by: O0oSKAMo0O ]</p>•)))2000 3.8L V6 FIREBIRD (Navy Blue) 5 speed <br />•Aluminum Alloy 3-piece custom built wheels - 17x10 (front)- 17x11.5 (rear) Tires:Front: 275/40-17 - Rear:315/35-17• Suspension Techniques 1 3/8 \" Solid front Sway Bar• H&R Springs • Koni revalved double adjustable shocks (front)• Bilstien Custom Revalved shocks (rear)• K&N •Magna Flow Dual Exaust• Stock wheels W/Hoosier Road Racing tires • Sound System•<br /><a href=\"http://www.cardomain.com/id/o0oskamo0o\" target=\"_blank\">•THE RIDE•</a>
The steering wheel is fine but the car seems to drift and I don't believe its been aligned since it came out of the factory. Any ideas?1999 Camaro Hugger Orange 3800 A4 <p>Mods-SLP SS exhaust, K&N, SLP STB, SLP SFCS, 1LE Sway Bars(32/19), 99 C5 Wheels on 255/45ZR17\'s-17\'s on all corners...Non-Y87
By all means get an alignment if you think the car needs one. However, it may not affect your issue. Low profile tires tend to follow road irregularities more. It's a big reason why car manufacturers use higher profile tires.2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
