Should I replace rear pads?? - FirebirdV6.com/CamaroV6.com Message Board
  • Should I replace rear pads??
    I'm getting ready to do a front rotor/pad swap on my front wheels. As far as the rears go, could I get away with just replacing the pads? The car has 36,000 miles on it and the rears are the original rotors/pads..
    --chris--
    they should look almost brand new, i wouldn't worry about it...but you can feel free to take a look at them to reassure yourself of this when your putting the front ones on. It's cake to change out the front ones, did it in 15 mins for both sides
    2000 Y87 Bird M5 with mods<p><a href=\"http://www.vzavenue.net/~ngeorg/\" target=\"_blank\">http://www.vzavenue.net/~ngeorg/</a>
      Yep, whay he said...Just pull your wheel and take a look...If they are getting pretty thing, replace, if not, don't.
        Are you replacing the rotor cause it's been damaged, to better performing rotors, or is it because some shop told you to? The fronts are guaranteed to wear faster than the rears. Not sure about cars with brake-proportioning systems though. If the pads are just worn out, then replace only the pads. No need to replace rotors, unless you had them turned a couple of times already or if they are damaged.
        [img]graemlins/burnout.gif[/img]
        1999 Pewter Camaro M5<br />Y87 Performance Package, Sport Appearance Package, Diamond Clears<br />Factory SS Hood, Free Ram Air Mod, Whisper Lid w/ K&N Air Filter<br />CarSound Cat 94009, B&B Tri-Flo w/ Quad Tips<br />BMR SFC, BMR STB, KVR Blank Rotors, Hawk HPS Pads<br />Black Painted Calipers w/ CAMARO Decal, 245/50 Dunlop SP Sport 5000<br />20% Rear 35% Side Tint, Red Reflective Inlays, Invincishield<br /><b>Young girls avert their eyes, weak men tremble, Ford dealers faint.</b>
