Since you guys seem to know alot about bushings, Where can i buy some stock replacement rubber bushings for my front lower controle arms?
Why isn't Polyurethane a good bushing material?
Stock replacement ones, you should be able to order them form any auto parts store.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
you should at least replace the bushings with hard rubber though (the stock rubber leaves a lot to be desired).2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
1 degree of roll to 1 degree of twist, you jsut gave a perfect explanation of why everyone should be running rod ends.
rubber bushings, along with a gidft for undesired deflection also will have a greater tendancy to twist up and then unload like a spring since teh material is soft. yet another thing you can avoid with a set of poly bushings.
later
timNJ SPEEDER<br />1976 Camaro LT<br />Crate 350, TH350, 3.90 posi<br />New Jersey F-Body Owners Association<br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
