Air Lift's "Drag Bags" solve the torque vs. traction equalization issue for drag racers! On a rear-wheel-drive car, engine torque creates a twisting effect which presses down on the left rear and right front wheels creating a corresponding lift on the rear rear and left front. Every drag racing fan has seen this body twisting action as a car leaves the line. This lift on the right rear results in it doing less work since there's less weight and consequently it will spin the right rear more than the left. To get maximum possible forward thrust, both tires must be equally loaded. Pre-loading your suspension with a set of drag bags air springs evens up the loads between the two wheels to achieve maximum potential forward thrust.
Or
Air Support.
Engineered as an add-on helper spring for coil spring suspensions, AirLift 1000 Air Springs are ideal for the rear coil springs of many passenger cars and some SUV's, that tow or carry light to medium loads. AirLift 1000 features an easy do-it-yourself installation with simple hand tools.
# Features and Benefits of AirLift 1000 Air Springs: Provides a more stable ride and improves poor handling and braking.
# Fits open coil springs in vehicle front or rear.
# Up to 1000 lbs. of leveling capacity. (NOTE: Never exceed the manufacturer's recommended GVWR).
# Air adjustablity allows you to customize the ride you want.
# Reduces roll, sway, and bottoming out.
# Tough molded polyurethane.
# Each kit is complete with air springs, air lines, fittings, mounting hardware, and a detailed installation manual.
Features and Benefits of Air Lift 1000 ''Drag Bag'' Air Springs:
# Solves Torque vs Traction Equalization Issues
# Allows preloading of your suspension to eliminate excess right rear spin
# Eliminates chassis twist on launch
Does anyone have these? How would these fair off the drag strip?
