I drove up to Trans Am Creations, bought their drum to disc conversion. Had it installed at a local garage, with mixed results. The garage is telling me the back brakes aren't getting enough fluid now. TACreations tells me the proportioning is done in the ABS unit, and they've never had to change anthing before. The garage didn't make new rear metal brake lines, they just twisted my old drum lines to take up some of the excess slack. Did any of you who have done the swap require any additional parts besides:
Calipers, pads, rotors, e-brake cables, and mounting brackets?
It does feel like the front brakes are doing more of the work than they should, especially at higher speeds. The pedal is nice and firm at low speeds, but has more travel before you really feel it start to engage the brakes at speeds around 40mph or higher. It could be the bias is wrong, could be bled wrong at the shop, or could be a bend was made in the brake line too sharp. Anyone have any thoughts?
There's another issue with them too, I'll go into detail with that later.
