front sway bar end link kit - FirebirdV6.com/CamaroV6.com Message Board
  • front sway bar end link kit
    i was changing my oil today and noticed that my front sway bar link kit was gone on the driver side(the thing that attaches the sway bar to the body). i do not know what is going on, about a year ago, the same thing happened when i was changing the oil and i replaced both sides with poly bushings. what could be causing that side to break the end link like that. i am just trying to figure out what to fix so that i dont have to keep buying those end link kits.
    95 3.4 m5- comp 206/212, 1.6 roller rockers, pacesetter headers, magnaflow cat, dynomax 18\" bullet muffler, ss muffler and tips, msd 8.5 wires, 32mm sway, umi sfc,
    When you replaced it, did everything line up right? Did you check to make sure that the sway bar wasnt bent or damaged when you replaced the endlinks? Check the bracket where the endlink bolts to the body and see if that is bent too....
    - Justin
    <a href=\"http://www.njfboa.org\" target=\"_blank\">New Jersey F-Body Owners Association</a><br />1987 Camaro LT - 400sbc, Aluminum L98\'s w/valve job, Comp XE 274, Q-Junk 750, 3.23 posi, 4.10\'s soon.<br /><br /><a href=\"http://www.njfboa.org/forums/viewforum.php?f=11\" target=\"_blank\">East Coast F-Body Nationals - August 14, 2005</a>
      yeah, everything looked ok, but i will look at it again, it just seems weird that it keeps breaking, something is probably bent or out of alignment.
