Wheel bearing... - FirebirdV6.com/CamaroV6.com Message Board
Wheel bearing...
  • Wheel bearing...
    I believe the front drivers wheel bearing is gone.
    I jacked up the drivers side of the car and got some play but very little from it. I did the same to the passenger side and got very little play (perhaps none at all).
    Would it be a good assumption to say its the drivers side? As well when making a right corner at highway speeds (when the pressure is on the the drivers wheel) It becomes really noisy... sounds like a gravel road or something...
    1996 Camaro<br />3.8, Auto, Black<br />No mods yet...
    it certainly sounds like your bearing is gone. Should be an easy swap as we have sealed bearings, but it ain't cheap. Unfortunately with a sealed bearing what you have done is really the only way to tell.
    One other thing though I'd check the tie rod end also. Those can fool ya into changing a wheel bearing sometimes. But it sounds like the bearing.
    -Brad
    2000 V-Star Custom 1100
    :rock:
      Well it turns out both front wheel bearings were bad. No one had them in stock. I ended up getting a set of used ones from a junk yard. But the noise and sloppy front end has been cleared up.
