Power steering cooler installed - FirebirdV6.com/CamaroV6.com Message Board
  • Power steering cooler installed
    When I was road racing a few weeks back, I literally boiled the power steering fluid. Losing your steering on a road course is [img]graemlins/omg.gif[/img]
    The cooler is the optional LS1 cooler that mounts inline with the radiator hose. Bought it from gmpartsdirect.com. Install was pretty straightforward:
    1. Drain coolant and p/s fluid.
    2. Mount cooler in lower radiator hose.
    3. Plumb cooler in low pressure p/s return line between rack and reservoir. Hoses set up for cross flow for more efficient cooling.
    4. Refill and bleed coolant and p/s fluid.
    While I had the coolant drained, I also swapped in a 180F thermostat to replace the stock 195F one. Filled coolant with 20% dexcool in distilled water with a bottle of water wetter thrown in. Power steering filled with Red Line.
    Pic here:
    2001 Pewter Firebird Y87, M5
    Go Sabres!
    NICE.. those units are definatly worth it for ax and road racing.. i really need to get one.. but i am kinda lazy.. how much was it? where did you pick it up?
      Picked it up from gmpartsdirect.com, it was about $95. Part #10417037
      The air/oil coolers are definately cheaper ($30-40), but I didn't think they'd work as well - you aren't moving fast or long enough in autox to get enough air over them, this one is full time. I should have taken a picture of the inside too, there's some pretty trick channels like a heat sink to pull more heat out of the oil into the water.
      Get the 3/8" transmissiom/oil cooler hose (hot oil resistant), hose clamps from auto part store. Ace Hardware had the barbed tee used to join the hose coming out of the rack with another piece to reach the cooler (can't see this in the picture).
      -Jeff
      Go Sabres!
        i've seen them go on ebay for about $25-$30
        merlin
        2002 Firebird<br />2003 Yamaha YZF 600R
          That's true, used ones do pop up every now and then. I wanted new though - there's small passages for the coolant to flow through ringing the main pipe (like a heat sink) that I didn't want to have to clean out if they were clogged. I generally don't ebay much either.
          -Jeff
          Go Sabres!
