the crossed drilled sloted rotors for my car, 2000 v6 camaro, how big of a difference is there with stock pads and lines
ROTORS!!!!
none...a higher price is all
the purpose of slotted/drilled rotors is to let gasses that build up inbetween the pad and rotor from high performance pads (ceramic and racing pads) in fact with stock pads, ur braking performance would actually decrease due to the reduced surface area of the rotor from slotting and drilling...unless u upgrade your pads stick with stock replacement rotors1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
Braking wouldn't necessarily decrease. The slots/holes also help keep your rotors cool, so if you do a lot of heavy braking, you will see a difference.
- Justin<a href=\"http://www.njfboa.org\" target=\"_blank\">New Jersey F-Body Owners Association</a><br />1987 Camaro LT - 400sbc, Aluminum L98\'s w/valve job, Comp XE 274, Q-Junk 750, 3.23 posi, 4.10\'s soon.<br /><br /><a href=\"http://www.njfboa.org/forums/viewforum.php?f=11\" target=\"_blank\">East Coast F-Body Nationals - August 14, 2005</a>
and don't forget about braking in the rain. BIG diffrence95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------> <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
