how often do you put air in your tires? - FirebirdV6.com/CamaroV6.com Message Board
  • how often do you put air in your tires?
    I hate my tires. I need to put air in them at least once a week and I know this can't be normal because I've never had to do it that frequently with any other vehicles. I have the stock chromed salad shooters w/235/55/16 Cooper Cobra Radial GT's. I'm not impressed with the Coopers anyway, but this can't be normal. I loose 3 to 5 psi in less than a week. I usually fill it to 33 to 35 cold psi.
    How often do you guys have to put air in your tires?
    1996 Polo Green Metallic Camaro:<br />SLP CAI, Carsound/Magnaflow 3\" in/out cat, Flowmaster 2.5\" cat-back... sounds great
    Take them out to a tire place, and have them check the valve stems.
    2000 Camaro 3.8 <a href=\"http://www.cardomain.com/ride/2040383\" target=\"_blank\">http://www.cardomain.com/ride/2040383</a>
      already done that. They said there's nothing wrong with the valve stems. I didn't believe them so I took it to another place, said the same thing.
        i rarely put air in mine. i check it once every month or 2. hardly ever needs it.
          that happened to me b4 so i felt for a puncture or nail or sumting. didnt find ne thing so i thought it was not sealed properly but when i took it off my dad found the screw. the others were perfect, when i regularly checked themonce a month) they were right on
          -RJ \"Like trail mix I\'m a lil sweet but mostly nutty\"<br />Metallic Blue 2001 3.8 Firebird M5<br />FRA,Smoothed Air lid, Homedepot Intake, K&N Air Filter, MSD Coils & Plug wires, Iridium Plugs, Flash Tune, 2.5 Flowmaster Catback.
            new tires, or your rims might be bent
            WAWA-A-HOLIC
              all 4 rims? what are the chances of all 4 rims being bent? especially because I'm not rough on my car at all.
                I only put air in like every 3 months....or at least check it...most the time they dont need it.
                  all you guys keep it around 33 to 35 psi right?
                    I havent put air in my tires for months. I gotta check them, thanks for reminding me.
                    Black \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
                      I have one cooper cobra that needs air about every other week, but that's most likely due to corrosion on the aluminum rim. the others are absolutely fine.
                      - Justin
                        Mine leak and I was told my chrome rims are corroding where the aluminum and chrome meet. The aluminum rims will corrode over time and affec the seal between the tire and rim. By the way, read your door sticker, the proper cold pressure is 30 psi front and back.
                        1999 Y87 Camaro<br />Whisper Lid, SLP SS Takeoff Exhaust
                          I have two that I have to add air to every week or so. I have stock rims and goodyear eagles.
                          Jessica :)<br />Kansas: There\'s no place like home...99 Firebird Blown/6lbs, Eaton w/3.42\'s CI headers Z28 Exaust<br />CAI, #36 injectors Intense PCM
