SQUEAKING from back right tire - FirebirdV6.com/CamaroV6.com Message Board
  • SQUEAKING from back right tire
    hey i got one?!
    theres a rapid squeaking noise coming from my back right tire, i dont know if its the breaks or what. it happens when im driving at any speed and when i apply my brakes! any one know.
    its doesnt normaly sound like the usual brake problem.
    sounds like when you are messing around on the bed with your significant other on a squeaky bed at warp 3! thats the best comparison i can come up with sorry!
    can someone help?
    98 firebird v6<p>venom member #6<p>40 series flowmasters, FRA w/ K&N filter. a big engine, batmobile floor mats,<br />more to come:<br />\"some technical stuff goes here\"<p>CLOSES THING TO THE BATMOBILE IM GONNA GET!.....for now!
    did you check all the normal stuff? (spare tire and jack)?
    Remember that sometimes, silence is the best answer.<br />Warren White<br />1996 PoloGreen Coup <a href=\"http://vampyr.settanni.net/\" target=\"_blank\">http://vampyr.settanni.net/</a> <br />\"Jealousy\"<br /> CTFBA member of the month Sept 03
      Also re-torque your LCA bolts. Too loose and they squeak. Too tight and the pop HARD!
      Jason McCallister, Founder & Webmaster<br /><a href=\"http://www.wtfba.org\" target=\"_blank\">West Tennessee F-Body Association, Inc.</a><br /><br />2000 Camaro - <a href=\"http://www.wtfba.org/site/view_member.php?ID=68\" target=\"_blank\">Details</a>
        Hey I think I might have the same problem, It sounds like my left rear shock or something, I think that it's the bolts being too loose, cuz Ive heard you guys talking about it before, so My question is how tight do you tighten the bolts, where are they at? what do I all tighten
        1997 Firebird Convertable White, with custom Purple pin striping and custom Purple detailing!!!<br />Y87 Performance Package W68 Apperance Package<br />Boydes, aluminum rims 16\" BMR STB <br />SLP Cold Air Intake 3\"hiflow cat 3\" dynomax custom catback, 2.5\" Flowmaster 80. Slp Take off Shocks, Springs And Struts. Transgo shift kit with corvette servo!<br />Sony Explode CD Player Kicker Comp VR 12, and Explode 760Watt amp!!!<br />5% Tint on the side windows, Correction officially 2% on the side windows, or at least that is what the highpo said and 15% on my rear window<br />Yup Purdy Car!!
          same here, where are the lca bolts located? is it hard to do or should i get a pro to do it? and what kind of tools do i need?
          im glad im not the only one here who has that problem [img]graemlins/fluffy.gif[/img]
            <blockquote>quote:</font><hr>Originally posted by REDBIRD327:
            same here, where are the lca bolts located? is it hard to do or should i get a pro to do it? and what kind of tools do i need?<hr></blockquote>
            Here's where the bolt is... click me
            It's the LCA bolt up front that needs to be re-torqued. You'll need to have a torque wrench set between 60-70 ft/lbs and torque them with the car flat on the ground (not jacked up).
            Good Luck! :D
              hey bro thanks for the tip and the pix! thats really helpfull! if you ever need anything let me know!
              thanks!
                Yeha thanks man, I really apresiate the help!!!, I hate that damn noise coming from the back, Nice link with pictures, that is really really helpfull
                  I have a squeak in my front right tire. And it is the brakes on my car. If it is your brakes you will notice that the rotor is hot and feel the heat fom the brakes.
                  good luck
                  Brandon
                  2000 Black T/A M6 343rwhp 349rwtq<br />11.94 @ 118 60\'1.79 Stock Internal<br /><a href=\"http://www.cardomain.com/id/demonicbird00\" target=\"_blank\">http://www.cardomain.com/id/demonicbird00</a> <br />AIM: W68Firebird97<br />R.I.P... Christine 12/25/02 <br />1997 Firebird W68 Black<br />14.887 @ 90.08
                  • Manimal
                    Coil springs
                    by Manimal
                    4 days ago
                  • Manimal
                    Newby here
                    by Manimal
