back wheels wobble - FirebirdV6.com/CamaroV6.com Message Board
back wheels wobble
  • back wheels wobble
    ok, i thought there was something wrong with my steering, because i can feel it jolt back and forth sometimes on turns. i took it to get looked at and they couldnt find anything wrong, but my frined told me that he could see my back wheels wobbling back and forth a little bit. anyone know what the problem is?
    <a href=\"http://www.cardomain.com/memberpage/483076\" target=\"_blank\">http://www.cardomain.com/memberpage/483076</a> <br />TSP rumbler, straight pipe, corvette servo. <br />Soon - 3.42+lsd,headers, cai,
    either you have bents axles or your lug nuts arent tightened all the way it seems. Does it make noise?
      no noise
        I'm baffled... :shrug:
          Do you have a bent wheel, missing a wheel weigh or somthing to that manner to cause it to wobble like that?
          ---Niño---<br /><i>95\' silver 5 spd</i>
            The wheel is not on properly? Bent axle? Could be a NUMBER of things, but first thing I'd do is take the wheel off and look around, then put the wheel back on and get it on there properly and smooth against the mounting surface [img]smile.gif[/img]
            Mustangs.. Come to the darkside...<br /><br />The dark side is the path to the shadow of greed. =D
              Take the cap to hide the lug nuts off of the rim! That will lower your 60' by .25 seconds, lol.
              FTRA kit, Whisper Lid, free ram air mod, Richmond 3.73 gears, Dynomax Catback, Poly Tranny mount, Vette Wheels, Expensive Audio equipment :). HID headlight Kit, Billet Grille, Billet Antenna, Eurotails, Carsound Cat
                1. Check your Panhard rod and it's mountings very carefully.
                2. If that or loose wheels isn't the problem see a pro immediately. This is nothing to mess around with.
                2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
