Painting calipers - FirebirdV6.com/CamaroV6.com Message Board
Painting calipers
  • Painting calipers
    Is it worth painting the calipers if you have stock 16in alloys? If so...I have a pewter car What color should i paint them?? I was thinking black or red.
    <a href=\"http://www.cardomain.com/ride/2038380/5\" target=\"_blank\">http://www.cardomain.com/ride/2038380/5</a> <br />pacesetter hi-flo cat, slp loudmouth 2 w/3.5 slash tips<br />Springtech lowering springs 1.75 drop<br />Hurst sts w/ short-throw stick<br />Not yet installed-pacesetter headers<br />Zexel-torson lsd<br />3.73\'s
    Any one?
      black
      2000 3.8 A4 Pewter Camaro
        Is it worth it even witht the stock rims on there?
          yeah
            any one have a upclose pic of what it looks like?
              http://www.camarov6.com/ubb/ultimate...=008248#000000
                yea ive seen that.. i meant with a stock rim. Should i use gloss paint even if im gonna clear coat it? or does the high heat not come in gloss
                  i think it does come in gloss but i also dont really think it matters if you use both. if not, just use the clear.
                    ok. What grit sand paper should I use to sand them down?
                      i dont think you need it. the caliper is rough already. all you need to do is clean the caliper with brakes cleaner and start painting.
                        Oh ok. Thanks for all the advice you've given me.
                          no problem. dont forget to mask things off [img]smile.gif[/img]
                            Where can i get the stickers that say "camaro"?
                              http://www.bfranker.badz28.com/vinyl/vinyl.htm
