as you all know i hit the curb the other day with my back right tire hard enough to crack the rim. well i got a new wheel and remounted tire and got it balanced. Now my right rear wheel is squeaking like no other and is really wobbley when i drive. Do you think i bent my axle?
is my axle bent?
This topic is closed.
is my axle bent?
<a href=\"http://www.cardomain.com/ride/2038380/5\" target=\"_blank\">http://www.cardomain.com/ride/2038380/5</a> <br />pacesetter hi-flo cat, slp loudmouth 2 w/3.5 slash tips<br />Springtech lowering springs 1.75 drop<br />Hurst sts w/ short-throw stick<br />Not yet installed-pacesetter headers<br />Zexel-torson lsd<br />3.73\'sTags: None
I need to know asap!<a href=\"http://www.cardomain.com/ride/2038380/5\" target=\"_blank\">http://www.cardomain.com/ride/2038380/5</a> <br />pacesetter hi-flo cat, slp loudmouth 2 w/3.5 slash tips<br />Springtech lowering springs 1.75 drop<br />Hurst sts w/ short-throw stick<br />Not yet installed-pacesetter headers<br />Zexel-torson lsd<br />3.73\'s
Could be. Put on a rim you know is straight, get the back end in the air, have a buddy look at the wheel while you put it in drive. (Do all the safety stuff plz, chock the wheels so you dont drive through a wall) let the wheel rotate and if it moves side to side or up and down, then yes you do. I believe we have 28 spline axles, if you need a new axle shaftJessica :)<br />Kansas: There\'s no place like home...99 Firebird Blown/6lbs, Eaton w/3.42\'s CI headers Z28 Exaust<br />CAI, #36 injectors Intense PCM
How much does a new axle shaft cost?<a href=\"http://www.cardomain.com/ride/2038380/5\" target=\"_blank\">http://www.cardomain.com/ride/2038380/5</a> <br />pacesetter hi-flo cat, slp loudmouth 2 w/3.5 slash tips<br />Springtech lowering springs 1.75 drop<br />Hurst sts w/ short-throw stick<br />Not yet installed-pacesetter headers<br />Zexel-torson lsd<br />3.73\'s
About how many hours would it take a mechanic to put a new shaft in??<a href=\"http://www.cardomain.com/ride/2038380/5\" target=\"_blank\">http://www.cardomain.com/ride/2038380/5</a> <br />pacesetter hi-flo cat, slp loudmouth 2 w/3.5 slash tips<br />Springtech lowering springs 1.75 drop<br />Hurst sts w/ short-throw stick<br />Not yet installed-pacesetter headers<br />Zexel-torson lsd<br />3.73\'s
-Remove rear cover and drain fluid.
-Unbolt brake calipers from backing plate and remove from rotor (remove the rotor too).
-Remove bolt from the pin in the center of the gears and remove pin.
-Push axle inwards towards the center of the car and the C-Clip will fall off.
-Pull axle out.
Installation is basically everything here in reverse. Don't forget to replace fluid. ;)sigpic
well, its not about how long it takes him, its what your going to be charged for the job. independent shop or not.
Originally posted by BLLDOGG:
well, its not about how long it takes him, its what your going to be charged for the job. independent shop or not.<a href=\"http://www.cardomain.com/ride/2038380/5\" target=\"_blank\">http://www.cardomain.com/ride/2038380/5</a> <br />pacesetter hi-flo cat, slp loudmouth 2 w/3.5 slash tips<br />Springtech lowering springs 1.75 drop<br />Hurst sts w/ short-throw stick<br />Not yet installed-pacesetter headers<br />Zexel-torson lsd<br />3.73\'s
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...3 hours ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....4 days ago
