got 1LE swaybars, now these bushings..... - FirebirdV6.com/CamaroV6.com Message Board
  • got 1LE swaybars, now these bushings.....
    I got a simple question. I got my swaybars and they came with bushings. Now......2 of these D bushings (i think that's what they are called) are flat on top, the other 2 have a notch in them. DO I put the notched ones up front or in the back?
    Let me know,
    Chris
    well if you have 4 of them.. 2 should be smaller the other 2.. the smaller go to the rear.. I'm willing to bet the notched ones are for the front.. one pair is bigger than the other pair right?
    [ January 22, 2002: Message edited by: black98V6 ]</p>
    -Brad
    2000 V-Star Custom 1100
    :rock:
      I assume you got 32mm and 21mm bars. The "D" bar bushings will have a different diameter inside, one 32mm and the other 21mm. Just match them up.
      Raven
