Offset - FirebirdV6.com/CamaroV6.com Message Board
Offset
  • Offset
    Whats the offset on our wheels? IS it 38mm? im looking into buying 18's, tire size what do you recommend and will anything rub in the front fender?
    96 3.8l green camaro Y87 <br />(Sold January 28th, 2004) New whip (02 Civic SI)<br />\"Out with the bad..in with the good; out with the bad in with the good!\"<br /> <a href=\"http://members.cardomain.com/themeangreen6\" target=\"_blank\">http://members.cardomain.com/themeangreen6</a>
    I think stock 16x8 alloys are 55mm. W6 and ZR1 SS 17x9's are (56mm usually). If you get in the range of 50mm -56mm you should not have too much trouble depending on width. [img]graemlins/burnout.gif[/img]
    Thanks, <br />JAM<p>02 Firebird GT
