has anyone had the problem of cross drilled rotors cracking? - FirebirdV6.com/CamaroV6.com Message Board
  • has anyone had the problem of cross drilled rotors cracking?
    has this happened to anyone? their are some fairly cheap cross drilled/slotted rotors on ebay i was thinking of getting -- http://cgi.ebay.com/ebaymotors/ws/eB...tem=2417937904 are these worth it?
    <a href=\"http://www.cardomain.com/memberpage/483076\" target=\"_blank\">http://www.cardomain.com/memberpage/483076</a> <br />TSP rumbler, straight pipe, corvette servo. <br />Soon - 3.42+lsd,headers, cai,
    My Eradispeeds are lifetime guaranteed not to. None should as long as you season them right.
      In street use, if they're not designed poorly, they will probably not crack. However I would not run cross drilled rotors even for street use.
      2002 5-spd NBM Camaro
      Details: www.1lev6.com
        <blockquote>quote:</font><hr>Originally posted by 97rs:
        has this happened to anyone? their are some fairly cheap cross drilled/slotted rotors on ebay i was thinking of getting -- <hr></blockquote>
        If they are "fairly cheap" then they probably will crack. Blanks that are crossed-drilled are junk. The rotors must be cast with the holes, and then finish machined to be any good. This manufacturing process will not get you inexpensive rotors.
        Raven
