Removing front calipers 97 car y87 - FirebirdV6.com/CamaroV6.com Message Board
  • Removing front calipers 97 car y87
    Ok i am doing my brakes right... i take off the wheel and what not so i'm at the caliper
    i use the c clamp to depress the piston and it goes in so now I go to remove the bolts...
    strange... no bolts??!?!
    so I removed what appered to be black rubber covers... so that slid right out... ok... now what I thought was the caliper pistons are blocking me from removing the caliper off the rotor to replace the pads..
    so i look at the left over metal bar that is preventing me from sliding the caliper off and the front of it has what looks to be a opening to use a rather large allen wrench??
    WTF is that I need help!?!?!!!
    NO, NO, NO!! You took apart the caliper!
    The caliper to bolted to the spindle by two bolts. They are what you remove.
    Here is a picture.
    http://cgi.ebay.com/ebaymotors/ws/eB...tem=2416785551
    [ June 04, 2003: Message edited by: FirebirdGT ]</p>
    Raven
      omg thank u.. ****ing haynes was not clear
        but i don't see that! :(
          -Remove the allen wrench bolts and the caliper will slide upwards (off).
          -The caliper is sometimes a B*TCH to remove, but it'll come loose after a few indecent words.
          -I remove the master cylinder cap, then slowly depress the piston in with the c-clamp.
          -Install the new pads in the caliper, and place back on the rotor.
          -Reinstall the allen wrench bolts.
          **Start car, leave it in park, and slowly depress the brake pedal a few times to build up pressure.
          -Marc
            I think you'll have to stick your head inside the wheel well and look at the calipers from the opposite side, then you'll see the 2 bolts holding it on.
            Maybe you're already doing that, if so, ignore this, if not, try it.
            1995 Firebird 3.4L<br /><a href=\"http://kansas.no-ip.com/\" target=\"_blank\">My Site</a>
              4 days ago
