I have a 1998 camaro with the eilbach 1.4 spring drop what size tires can i run. Will i still be able to run a set of 275/40/17 or will it have to be smaller. I think they might hit up front. I am also looking for a set of 17 inch rims that are very light and strong what should i use. [img]graemlins/burnout.gif[/img]
WHAT CAN I FIT
You will still be able to run the 275's in the rear, but I would only go with a 245 or maybe a 255 width in the front...I think that 255 would really be pushing it though.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
If you go with 275/40/17 tires on a 17x9 wheel, the total wheel/tire height will be less than stock, so you're okay there. It's the wheel width and tire width that you have to worry about. I feel that you'd have a better chance with 255/45/17s on a 17x8 wheel, because then you've satisfied stock total wheel/tire height and wheel width. The only issue now is tire width. First best thing to do is go to a shop and have them test mount a wheel w/ tire for you. Next best thing to do is take measurements yourself with the wheels straight, wheels turned left and wheels turned right.<a href=\"http://geocities.com/ex1zee28\" target=\"_blank\">http://geocities.com/ex1zee28</a>
you can still run 275/40/17's in the front w/ it lowered. thats what i have w/ rksport springs which lower it more than eibach prokit. my tires sometimes rub a little bit, but its not a big deal.94 Firebird - Red A4<br /> <a href=\"http://members.cardomain.com/predatorbird\" target=\"_blank\">http://members.cardomain.com/predatorbird</a>
