I've decided I want 255/50 kumho ecsta's on the rear but they don't makea 235/55 which I need for the front (I've got that size on now and it still scrapes a little). Would it look odd with 255/50s on the rear and 225/55s on the front?
Mismatched tire question.
<blockquote>quote:</font><hr>Originally posted by mdchaser:
I've decided I want 255/50 kumho ecsta's on the rear but they don't makea 235/55 which I need for the front (I've got that size on now and it still scrapes a little). Would it look odd with 255/50s on the rear and 225/55s on the front?<hr></blockquote>
Shouldn't look bad at all. The larger side wall on the 225 will match the smaller one on the 255. I think it will look fine.\"He\'s a nut bag. And just cause he has a library card doesn\'t make him Yoda.\" - Se7en
If you go with anything smaller in the front, go with 245/50, 235/55, 225/55, or 215/60
They should look fine, but I don't know why you'd want to restrict your rotation and handling capabilities by doing that. 255's really aren't terribly wide tires for the front IMO.2002 5-spd NBM Camaro
Details: www.1lev6.com
The 255s are for the back, I want beefier tires back there. I can't use anything wider than a 235/55 up front because they already scrape.Jeff R.<br />97 RED RS<br /><a href=\"http://camaro.rscpro.com\" target=\"_blank\">http://camaro.rscpro.com</a>
235's should not even come close to rubbing in the front. I'm running 255/45's and they don't rub. Do you have something done to your car that would make the tires rub?2000 GTP<br />Thrasher CAI, 3.4\" pulley, DHP PCM<br />Member RedLineVSix<br />Best ET-14.02<br />Best Trap-97.15
They stick out just pas the edge of the car, I have the truck version. I love the way it looks but it scrapes a little at low speeds.Jeff R.<br />97 RED RS<br /><a href=\"http://camaro.rscpro.com\" target=\"_blank\">http://camaro.rscpro.com</a>
