Problem with brakes.......need some help. - FirebirdV6.com/CamaroV6.com Message Board
  • Problem with brakes.......need some help.
    Okay, i asked this a while back and didn't find a solution. Please can i get some help! This started about a month ago. When i am braking to a stop in my car, the low track light comes on when the speedo gets to exactly 10mph and i hear a little grind noise and the car has a jerky stop. The brakes work perfectly at all other speeds; its only when i have rolled to almost a complete stop that this happens.
    Couple weeks ago i took it to the dealer, payed $80 for a diagnosis and they said they couldn't get it to do it (at this point it happened 95% of the time- go figure). Money well spent. A couple days later i put air in my tires (they were pretty low ~22-24psi) and washed the car. The problem then just stopped for about a week, and has just recently come back, though not as often as before.
    I recently learned about something called an abs speed sensor or abs wheel sensor. What is this? Could this be the problem? It makes sense b/c the problem temporarily stopped after messing with the wheels, but who knows? I would appreciate any feedback, as i am already out $80 and don't have a fix. Thanks. [img]smile.gif[/img]
    -Justin
    2001 Camaro Z28 (A4) Sunset Orange Metallic w/ T-tops, Monsoon Stereo, factory GFX, BMR STB from the v6, 18K miles<br /><a href=\"http://www.cardomain.com/id/jhkcam22\" target=\"_blank\">2001 Camaro Z28</a><br /><br />Dads car: 2002 35th aniv. Bright red Z28, fully loaded<br /><br />R.I.P.<br />1995 3.4L Camaro (A4) Bright Red<br /><a href=\"http://www.cardomain.com/id/jhkcam\" target=\"_blank\">1995 3.4 Camaro</a>
    i had the problem.. it stopped... but it stopped before i put air in the tires. i'll let u know if it comes back.
      yeah man there are sensors in the hubs of both front wheels and one in the rear end.. it sounds like one of those 3 sensors is acting up, I'd check for a loose connection in one of those
      -Brad
      2000 V-Star Custom 1100
      :rock:
        okay, i'm a dumbass when it comes to any kind of sensor.... how do i get to those sensors and what exactly am i looking for?
        Thanks
        -Justin
