suspension noise - FirebirdV6.com/CamaroV6.com Message Board
suspension noise
  • suspension noise
    ? for everyone about suspension noise
    been noticing some groaning from my back end during tight turns (more than 90 degrees) at moderate speeds (10-15 mph)
    groaning is kinda like the sound of a ship buckling under pressure in a movie.
    Well, I pushed down on the car to see how the shocks & springs are. And my driver's side rear spring is very squeaky. Easily audible. Not a high pitched squeak, is hard to describe in terms of something everyone may understand.
    Is this a problem or something to not worry about?
    Thanks
    2001 75th Anniversary V6 Pewter Firebird w/ Chrome Wheels, T-Tops, & Y87<br />Mods: Free Ram Air, !Silencer, Holley Filter, Full 3\" Hooker Catback, 3\" Cat<br />Best time: 15.095 at 90.00 MPH with a 2.127 60\'
    I had my car do the same as you described and it ended up being the rear end. I changed the rear diff fluid and my problem went away. Your car is new so I don't know if this is the problem or not but it sounds exactly the same as mine.
    Also I am running the Auburn LSD and you have the Zexel Torsen. They work differently so once again I'm not sure if this is the problem.
    Hope this helps.
    2000 GTP<br />Thrasher CAI, 3.4\" pulley, DHP PCM<br />Member RedLineVSix<br />Best ET-14.02<br />Best Trap-97.15
      You might want to check your Lower control arm bolts, on the back, cuz mine are aparently out of torque specs, cuz i have that weird noise from the passenger side rear. There are a lot of people that have that noise, and from what they have told me is that you probably need to tighten the bolts, to your lca. I still am having that problem, i had posted it before. somebody told me to tighten them between like 65foot lbs, and i had my tires rotated, and i had them do this, and they were alread at least that tight. so I don't know what to tell ya. but you might want to check those lca bolts
      1997 Firebird Convertable White, with custom Purple pin striping and custom Purple detailing!!!<br />Y87 Performance Package W68 Apperance Package<br />Boydes, aluminum rims 16\" BMR STB <br />SLP Cold Air Intake 3\"hiflow cat 3\" dynomax custom catback, 2.5\" Flowmaster 80. Slp Take off Shocks, Springs And Struts. Transgo shift kit with corvette servo!<br />Sony Explode CD Player Kicker Comp VR 12, and Explode 760Watt amp!!!<br />5% Tint on the side windows, Correction officially 2% on the side windows, or at least that is what the highpo said and 15% on my rear window<br />Yup Purdy Car!!
      • Manimal
        Coil springs
        by Manimal
        4 days ago
      • Manimal
        Newby here
        by Manimal
