deep grinding noise - FirebirdV6.com/CamaroV6.com Message Board
deep grinding noise
  • deep grinding noise
    There is a heavy grinding noise coming from my front axle. Im guessing it has something to do with the brakes. Because, the noise only happens when i need to brake hard and it happens around 20mph to 0mph. Mostly between 5 and a full stop. Also its not like an every time deal but it happens often. Also when i get off the gas it sometime makes a light reapiting grinding noise kinda like; ksh ksh ksh ksh. till i speed up.
    If any one can give me some tips ill be thankful
    thanx
    I've got the same exact problem, and I'm wondering what it is too.
    \'99 SDime reg. cab stepside<br />4.3/auto/3.42 open<br />Performance: 2.5\" from the y into a Magnaflow, modded stock airbox, MAF mod<br />Exterior: dropped 2/1, Gen 2 hood, clear corners, euro tails, billet bowtie, Xtreme wheels, shaved emblems
      Has either of you pulled the wheels off and checked the pads and rotors?
      2000 GTP<br />Thrasher CAI, 3.4\" pulley, DHP PCM<br />Member RedLineVSix<br />Best ET-14.02<br />Best Trap-97.15
        Wheel bearings, maybe...
        2001 Yamaha FZ1<br />1996 Camaro M5 Sexy Black<br />\'99 Vette Wheels with Nittos<br />1LE Swaybars/Endlinks<br />Bests: R/T .659, 60\' 2.179, 1/8 9.957, 1/4 15.6, MPH 87.26<br /><a href=\"http://www.camaroman.cz28.com\" target=\"_blank\">My New Website</a>
          ive checked me brakes and the little metal strip that warns you when the brake pad is low. and its not touch the rotor when I was in park.
