Ok I have a complete rear end. Everything is there that I need to do this drum to disc brake swap in my 97 camaro.
The only problem is the rear end is set up for 4 channel ABS with the ABS sensors on the back of the disc brakes. My current rear end is 3 channel ABS with the ABS sensor on the Differential Housing.
If I just do loochy88's swap, using my stock axels, will my ABS still work?
I am unsure. I know the ABS will still be plugged up since I am not changing the whole rearend. But I will also now have the other plugs for the 4 channel ABS and without them plugged up will the ABS still work? Will the ABS on the rear calipers originally set up for 4 channel ABS work inside the 3 channel ABS rear end and all the ABS still work correctly?
I know that may be really confusing but I need help here. I would love to just swap the whole rear end up I know that my ABS will not work then.
