Tire size for 17x9.5? - FirebirdV6.com/CamaroV6.com Message Board
  • Tire size for 17x9.5?
    My question is will a 245/45/17 fit on a 17x9.5 rim?
    I know 245/45/17 = about 9.6" wide. Anybody tried this?
    Thanks, <br />JAM<p>02 Firebird GT
    i have 275 40 17s on 17x9.5 rims in the front
      Yeah, I want to know if I can go a bit smaller in the front. This is for the set she got me I was telling you about. Just thought 275 width was too much in front. But to match the overall diameter the only one that I could find was a 245. Anybody know if this will work, or has done it?
        Yes you can go with a smaller tire I have 245/40/17 all the way around on 17X9.5s
          Thanks Nachius!!
          [img]graemlins/burnout.gif[/img]
            Also P285/40's fit :D
            2002 5-spd NBM Camaro
            Details: www.1lev6.com
              I had 245/45/17's all around on my TTII's for over a year and it was fine. Here's a pic of my car with the 245/45's to give you an idea. I was more focused on getting a pic of the shine though :D
              waxed with 245/45/17's!!
              1994 Camaro 3.4L M5 R.I.P.<br />You know what they say- a small engine means big... errr... e/t\'s<br /><a href=\"http://www.pbase.com/rrj72/the_accident\" target=\"_blank\">www.pbase.com/rrj72/the_accident</a><p>replaced with: red 97 A4 vert (my brothers as soon as i find my REAL replacement)<p>soon to come: 1969 RS/SS<p>\"All you need are the esentials: scented candles, massage oil, and Berry White write that down.\" -Van Wilder
                Thanks for the pics. That really give me an idea of what that size looks like. My reasoning is I have ZR1's.
                17x9.5 in front
                17x11 in rear
                and I thought of running
                275 in front
                315 in rear
                but to try and save a few lbs of weight I though if I use the smaller
                245 in front
                275 in rear
                and seems that the 245 will look just fine up front. Specs seem that is about 10 inches wide roughly. I think that should be plenty for the front.
                Ideas, comments, advise?
                  Do you guys know about how much weight this set up will save Vs. the 275/315 combo?
                    no idea about the weight.... post pics when you get them on.. i still have my zr1 wheels i might just swop them out every 6 months(new pics of the torque thrust IIs on my web page
                    [ November 23, 2002: Message edited by: MEAN 98 ] [img]smile.gif[/img]
                    [ November 23, 2002: Message edited by: MEAN 98 ]</p>
                      I like the torque thrusts. Where did you get those? Are they the same offsets as the ZR1's?
                      Anybody else have an idea of about the weight differance?
                        the 245/45 sidewall will roll in slightly on a 9.5" wide rim FYI. It's not bad at all but something to keep in mind... i thought it looked pretty tight. It may contribute to a little rougher ride if it takes away some sidewall cushion but not bad. i wouldn't go any larger then 275's on your car because you're going to notice a lot more "drag" on the road once you get the bigger tires on.
