replaced the disc pads tonite... - FirebirdV6.com/CamaroV6.com Message Board
  • replaced the disc pads tonite...
    Hello!
    I replaced the disc pads tonite for a set from autozone for 16 bucks with a lifetime warranty... but heres my question, all I did was pull off the other ones , clamp the caliper so that it squeezed it closed so that I could stick on the new ones ( I monitored the fluid level, never overfilled) and stuck them on, piece of cake. Did I do this right? i took it out for 2 mins and it felt ALOT better... thanks!
    amrk
    RedLineVSix <br />95 Patriot Red Trans Am, M6, 3.42\'s,no rear tires<br />(SOLD!)97 Silver Camaro 3.8 Liter A4 3.42 + LSD, 1pc DS, and one messed up speedo :)
    yep sounds right
    2002 Pewter Camaro SS M6/Hurst<br />345 HP SLP Performance Package<br />BMR STB, K&N, Lou\'s Short Stick, SSRA, ASP Pulley, SLP SFC\'s<br /><br />DYNO 8/18/04 STOCK: 326.43rwhp/342.44tq<br /><a href=\"http://www.cardomain.com/ride/530894/\" target=\"_blank\">My Car</a>
      Did you apply an anti-squeal coating to the back plates of the pads?
      Did you apply caliper lube to the caliper bushings?
      Both are not absolutely necessary ... but are good preventive maintenance practices.
      You can achieve anything for which you are prepared to pay the price.<br /> --ATTILA THE HUN
        Hello
        Nope, I didn't , but it feels fine! [img]smile.gif[/img] thanks tho!
          If you get a little more money, as soon as those pads go bad (and they will very quickly) get some quietstops, i have the same brakes as you, and they're the cheapest you can get. For me they started squealing after a few weeks on brand new rotors. They create so much break dust it's unbelivable.
