brake squeek pads&rotors good - FirebirdV6.com/CamaroV6.com Message Board
  • brake squeek pads&rotors good
    i had my rotors turned and my pads replaced in the front of my 95 camaro in the spring. well now they squeek. ive put a few thousand miles on them and if i glazed the pads when they where new i think it would have shown by now. i have plenty of pad left and i dont brake hard usually. my rotors look fine, but when i brake slow like i always do and ease into it they squeek untill i press them down 3/4 the way. when i press them 3/4 of the way they grip alot harder than they where befor so its like i can easy into my brakes then they go kinda hard at a certain point. anyone know whats wrong? my rear drums arnt making this noise and i think it is coming from the driver side.
    <a href=\"http://camaroz28.cardomain.com/id/onoiocoko\" target=\"_blank\">http://camaroz28.cardomain.com/id/onoiocoko</a> <br />\"there are three kinds of people - those who can count and those who can\'t\"
    Try braking really hard from about 60 once in awhile...I find it helps when mine start squeaking.
      Make sure you put pads that actually fit on your car when you replace the pads. I had the dealership replace my pads and they didn't put the stock ones back on they "upgraded" without telling me. Brakes squeeeeeeeked worse then when I brought them in. Found out the pads BARELY didn't cover everything said they didn't even notice it untill they took it all off and look with a magnifying glass.
