hey, I noticed that my rear end is shifted over a little bit... Do you guys think it is my tractions bars bent at where they meet with the frame??? Thats all i can assume... And if it is, should i just take it to my dads shop and throw it on the frame rack real quick and straighten it out, or replace them (i really dont want to!!) but if i have to i will!
thanks
Chris
<a href=\"http://www.cardomain.com/ride/2222522\" target=\"_blank\">http://www.cardomain.com/ride/2222522</a> <<<<< CHECK IT OUT!!!<br /><br />HELP ME WITH A TURBO SET UP!!! PLEASE
The 'traction bars' (I'm assuming LCA's) wouldn't / couldn't bend ... I'd check your PHR bushings and mounting brackets.
The LCA's monitor front to rear movement, the PHR monitors left to right movement.
But if your dad has a frame shop, it should be a no brainer.
Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...
