hey just outta curiousity for those still running the factory 16" aluminum wheels what kind of weights do yall have on em for balancing? stick on that go on the inside or the kind that clamp to the edge on the outside?
stock rims and balancing
Originally posted by nda0602v6:
My factory rims use clamp style weights but only on the back, none on the front.
Edit: Back of the rim, you don't see the weights.
[ August 06, 2004, 12:01 AM: Message edited by: silvachris1 ]~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
The stick on weights are a pretty new thing, there very nice.1999 Pontiac Trans Am M6 Far from stock.....
Stick on weights are a little more tricky to work with than standard clamp on weights but they work just the same.<a href=\"http://www.cardomain.com/id/kefkafloyd\" target=\"_blank\">http://www.cardomain.com/id/kefkafloyd</a> <br />Red 1997 Pontiac Firebird 3.8L A4 w/ Y87
Yeah clamp on weights on the outside of nice chrome rims look like crap, not to mention discoloring the wheel where the weight was. Some aftermarket rims can only use stick on weights since there isn't even a lip to use a clamp on style weight.2006 Tiburon
As far as balancing goes. They both balance out the same. One isnt more balanced then the other method. Its just the fact of appearance. My ZR1's have rim flanges on both sides, but I chose to do the stick-on weights/hammer on weight method.I would reccomend using the sticky weights if possible, cause the hammer on kind can scratch of your clear coat, and also leave corrosion on the rim. BTW, I work at NAtional tire and battery, so i have to deal with this stuff alot. ;)Jordan<br />15.09@90.7<br /><a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=21\" target=\"_blank\"><b>1995 Camaro 3.4 M5</b></a>
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...1 week ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....3 weeks ago
