Well i got up front to replace my shocks and springs and couldnt get the A-arms to seperate. also is there anyway to get them to seperate withough the correct tool lol i know i have done it before but did by accident wondering if there are any home remedys to this.
Best way to pop open Front A-Arms
<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport HeadersTags: None
You shouldn't have to, search my earlier posts here for install guides. One has an install without taking the a-arms apart.Drivetrain Moderator - "There are no stupid questions, only stupid people!"
2001 Pewter Firebird Y87, M5
Go Sabres!
You remove the upper spindle cotter pin and bolt and it should come right off the upper A-arm. If you remove the front endlinks you can get more drop from the lower A-arm which makes it easier to get the shock in and out, although if you've got some age to the links they may twist off or require cutting to get off.
Once the spindle is disconnected from the upper A-arm you simply remove the bolts from the top of the shock tower (in the engine compartment) and it should drop right out. You may have to move the master cylinder out of the way to get to the ones on the driver's side, and the A/C lines kinda interfere with the ones on the passenger side. There are 2 bolts that hold the shock to the lower A-arm.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
