wheels - FirebirdV6.com/CamaroV6.com Message Board
wheels
  • wheels
    to get 71x11 in the back do you have to do anything to the wheel wells ?
    1997 WHITE 30TH ANNIVERSRY 3800 II M5
    depends on the offset.. the zr1s tend to rub the inner fender wells(have to use a hammer and a pipe to gently knock in the areas where it is rubbing , where the torque thrustIIs stick out a little more rubbing the outer fender lip and i used a jigsaw with a shorten blade to cut my inner fender lips out .. i lowered it and so far no rubbing [img]smile.gif[/img]
      i went to a wheel store in denver and they said the torq thrust wouldnt work w/ the ofset on my car i imagine the offset on my car and your is the same did you have to do anything to make them work?
      thanks
        http://www.americanracing.com/wheels...=Torq-ThrustII this link has the wheel numbers you will need ... i went to sears and they ordered these wheels and it was $1287. installed i had tires ....17x11s rear, 17x9.5s front or you could buy my zr1s$700.
          THANKS! i love the style of the toeq thrust wheels did you have to put special spacing or anything like that?
            no spacers ... cut outer fender lips (scraping) took 5 minutes each side....
