to get 71x11 in the back do you have to do anything to the wheel wells ?
wheels
depends on the offset.. the zr1s tend to rub the inner fender wells(have to use a hammer and a pipe to gently knock in the areas where it is rubbing , where the torque thrustIIs stick out a little more rubbing the outer fender lip and i used a jigsaw with a shorten blade to cut my inner fender lips out .. i lowered it and so far no rubbing [img]smile.gif[/img]
http://www.americanracing.com/wheels...=Torq-ThrustII this link has the wheel numbers you will need ... i went to sears and they ordered these wheels and it was $1287. installed i had tires ....17x11s rear, 17x9.5s front or you could buy my zr1s$700.
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...5 days ago
