V8 vs V6 sway bars? - FirebirdV6.com/CamaroV6.com Message Board
V8 vs V6 sway bars?
  • V8 vs V6 sway bars?
    What are the different size sway bars that come on V6 and V8 f-bodies?
    My old car.<br />2000 Firedird 5-Speed<br />1/4 E.T. 15.601 @ 88.659 w/2.411 60\'<br /><br />New car.<br />1999 T/A 6-Speed<br />1/4 E.T. 13.181 @ 106.971 w/2.15 60\'
    http://tech.firebirdv6.com/suspension.html
    V8s are 30/19 or 32/19 depending on Z28/SS or TA/WS6
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      Essentially what Dominic said. V6 sway bars were 30/17 up until '98, they went to 28/15 from 98+. V8 sway bars are 30/19, unless they are 1LE, then they are 32/21.
      2001 Onyx Black Camaro M5-Totalled<br />2005 Ford F150 XLT 5.4L<br /><br />\"To make peace, prepare for war.\"
        Thanks guys. So here is my question, if I put a 28 mm sway bar on the front of my car, will it launch better at the track? I've always heard if you remove the front sway bar it helps with weight transfer when launching. So if I put a thinner front sway bar on, will that help a little? I'm not crazy about the idea of removing the sway bar on my everyday driver. Thanks in advance!
          Its very simple to remove and reinstall, takes all of 10 minutes [img]smile.gif[/img] I'd just do that or do nothing once you arrive at the track.
            I installed 1LE sway bars front and rear on my car and couldn't believe the difference. By far the best mod so far!
            1997 Camaro,<br />SLP cold-air, Hooker Supercompetition catback, Air temp. module, Powerstat thermo, 1LE Aluminum drive shaft, 3.42 POSI rear, 1LE sway bars front & rear, Powerstop crossdrilled rotors on all corners, Torque Thrust II\'s (17x9.5 front & 17x11 rear), and a couple other goodies. <a href=\"http://www.villagephotos.com/pubbrowse.asp?selected=84487\" target=\"_blank\">http://www.villagephotos.com/pubbrowse.asp?selected=84487</a>
              I don't want better handling, I want better launching. I don't like the idea of taking my sway bar off every time I go to the track. I like to run my car in street trim. Thanls for the help guys. So will it help with weight transfer at all?
                <blockquote>quote:</font><hr>Originally posted by LimitedE:
                I installed 1LE sway bars front and rear on my car and couldn't believe the difference. By far the best mod so far!<hr></blockquote>
                Was the difference in handling or from a dead stop launch?
