Tire went to heaven :( - FirebirdV6.com/CamaroV6.com Message Board
  • Tire went to heaven :(
    Hello!
    My rear right tire went flat, and the glass in it is too big to repair the hole, so i'm going to buy 2 new tires for the rear end. I was just wondering if it'd be ok if i put 245 55 16's on the back instead of the ole 235 55 16s? Thanks!
    Mark
    RedLineVSix <br />95 Patriot Red Trans Am, M6, 3.42\'s,no rear tires<br />(SOLD!)97 Silver Camaro 3.8 Liter A4 3.42 + LSD, 1pc DS, and one messed up speedo :)
    Shift points will be slightly off.
      You will be fine running either 245/50R16 or 255/50R16s in the rear, the P255/50R16s are the identical height to what you have now and the 245s are a hair shorter (more turns per revolution).
      2002 5-spd NBM Camaro
      Details: www.1lev6.com
