Question on Torque settings? - FirebirdV6.com/CamaroV6.com Message Board
  • Question on Torque settings?
    Want to double check the torque setting specs before puting on sub-frame connectors and STB this comming weekend. Are the following settings correct?
    Rear LCA bolt "head" = 80ft/lbs.
    Rear LCA bolt "nut" = 60ft/lbs.
    SLP supplied bolts for sub-frame connectors that are 7/16" = 55ft/lbs
    Tunnel brace bolts = 27ft/lbs
    STB = 35ft/lbs.
    Did I miss anything? Please adivse. :D
    Thanks, <br />JAM<p>02 Firebird GT
    Those all sound right, all torque spec's can be found on install university if you're picky [img]smile.gif[/img] .
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      Thanks!! [img]graemlins/burnout.gif[/img]
