Name this part
I can make out the lower shock mount but I can't tell which missing piece you're referring to.
The rear swaybar is connected to the axle on both sides with bushings and clamps. It is connected to frame brackets with endlinks.
My suggestion would be to get an Energy Suspension kit that replaces all the pieces. This would be an excellent time to upgrade to a 19mm rear bar as well (since the bushings are sized for the bar). 19mm bars came on the V8 models and can be found used very inexpensively.
http://store.summitracing.com/partde...3&autoview=sku1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
You see the arm? There's suppsed to be another piece connecting that with the sway bar. I don't know what it's called exactly I remeber the mechanic calling it stablizer something.
I wanted to get it at autozone and possibly out it on myself.97 Camaro rs 3.8<br />Flowmaster catback<br />High flow cat
Okay, I couldn't make it out at first looking at the picture but if you're talking about the circled area that is a swaybar link or endlink.
Like I said, might consider upgrading both as well as the bushings at the same time.
If you buy just one they're like $5 at Advance for the standard or $6 for "heavy-duty" which uses poly bushings. I wouldn't mix one stock with one poly though. Front and rear bars use the exact same endlink.
Ok thanks, I think it's also called the stablizer bar link. That's what they're listing them on autozone.
I'll replace it as soon as I can. Was it unsafe driving it like that?97 Camaro rs 3.8<br />Flowmaster catback<br />High flow cat
stabilizer bar = sway bar = anti-roll bar
The car would exhibit more body roll in the turns without the bar connected. More body roll = less tire contact so it could be unsafe if you like to take turns fast.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
good then its not just me.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...8 hours ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....4 days ago
