Kuhmo 712 255-50-zr16 !! - FirebirdV6.com/CamaroV6.com Message Board
  • Kuhmo 712 255-50-zr16 !!
    I got these tires mounted yesterday they kick A$$ they dont rub no matter how you turn they stick to corners like glue. Now i had the god forsaken 215-60's befor so this is a rather large difference. The ONLY bad thing i have to say about them is that they walk over the road quite a bit. but i can handle that for some awesome traction. so they get [img]graemlins/thumbsup.gif[/img] [img]graemlins/thumbsup.gif[/img] from me. Oh and they look SOOOOOOOOOOOOOOOOOOO much better now
    AIS 2 OHH the memories... Great times and putting names with faces.<p>From \"interesting\" hooters waitress(Did you guys FLY ? ) to pissing BMW owners off on the ride home. To ending up in Philidelphia and USING (hahaha) an ice machine. I had a BLAST.<p>Thanxs to all that showed up!!
    Does this size change your ride height? Any speedo changes? I'm still trying to understand the tire #'s game, so bear with me. [img]graemlins/dunce.gif[/img]
      I dont think it will change the ride height much. It might set the speedo off but just barely. Not enough to worry about.
        Yeh when i am doing 80 mph my speedo shows 79 !! wtf no big deal and the slower you go the less it affects it. It doesnt change the ride hight much but it does fill in alot of wheel well gap because of the width
          What about the odometer? Will the tire change affect this too?
          SLP C.A.I./Whisper Lid<br />K&N Filter<br />Flowmaster 50 series Exhaust<br />Catco 3\" high-flow cat w/<br />2.5\" I-pipe<br />Hurst Billet Shifter w/<br />Lou\'s short stick
            Anything that affects the speedo affects the odometer.
              you will have more fender gap between the tire and fenderwell. the 255-50's are about 1 in. smaller in diameter. the car will be about 1 cm.(1/2 in) lower to the ground too.
              2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
                Okay, if it affects the odometer then I have another question. If anyone can go and change their tires to a different size which will ultimately affect the odometer rating greatly in the long run, then wouldn't changing your tires simply be a legal way of commiting odometer fraud?
                  <blockquote>quote:</font><hr>Originally posted by blue streak 00:
                  Okay, if it affects the odometer then I have another question. If anyone can go and change their tires to a different size which will ultimately affect the odometer rating greatly in the long run, then wouldn't changing your tires simply be a legal way of commiting odometer fraud?<hr></blockquote>
                  could be. But you would have to change the tire size signifigantly to see any major changes in the milage.
                    no not really when you think about it.. what is an odometer reading?? well it tells you how far the car has gone, but more importantly how much the car was run...
                    so:
                    it takes x number of motor revolutions to go 50k miles...with stock tire height
                    with say a 5% taller tire it should take 5% less engine revolutions to go the same 50k miles.. ..so the odometer would only show 47500 miles when in reality the car has covered a distance of 50k but only had the wear of 47500
                    but here is the flaw in all these assumptions..
                    mileage is not necessarily an accurate measure of the use of an engine.. a more accurate way to measure use would be an run time clock.. measure the number of hours on an engine like they do with heavy equipment and boat engines..
                    edit:
                    just want to add this is really generalized.. and assumptions have been made to keep it simple.. just thought I'd add this last part to keep the more picky technical people happy.. ;)
                    [ April 26, 2002: Message edited by: black98V6 ]</p>
                    -Brad
                    2000 V-Star Custom 1100
                    :rock:
                      I put the 245's on my car and I am considering ditching them. If I drive down a crappy street I can't keep the car going straight... They are pretty good for highway driving 90+ mph...
                        I have no problems, same overall tire hieght. Just go ask a tire salesmen. There are books upon books full of info on what size tire you can fit with what rim and keep the same tire height.
                        1997 Dodge Viper GTS
                          I got new tires today 255 50 ZR16 to replace the original 235 55 R16's. The improvement is not as noticeable as from 215/60's, but still good!
                          It all started as a flat tire - but the tires were almost all worn out, so I knew it would happen sooner or later. Fortunately, I had no pressing appointment, plus I parked in the shade - nice for changing the tire. First time I'nve used the jack on the car. They've improved them alot over the 3rd gen's jack. In addition, the lug wrench actually fits correctly (the third gen's wrench did not fit so good). AND - the jack fit perfectly right under the W68 ground effects.
                          [ May 03, 2002: Message edited by: Everglades W68 ]</p>
                          I solemnly swear I am up to no good.
