i was wondering if anyone uses an aftermarket k-member, if you are please tell me how your steering is, if the lose of 75lbs made a differnce and how hard was the install?
PA racing K-member
Read this http://robmeadway.com/fbodysuspguide.html it has some info about aftermarket K-members down at the bottom. Basically if you get the K-member from PA get the road race option but personally i have come to the conclusion that an aftermarket K is not a worthwhile or wise mod unless you plan on the car being for track use only in which case turning is not a priority.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
You will get no noticable gain or loss from an aftermarket K-member other than weight loss. And yes, it would be hard to install. I had mine installed for me. My suggestion would be to find a reputable body shop to install it because they tend to have lower hourly rates than regular auto shops.
g2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
well the reason i was looking into this was because i was planning on putting a turbo in over the summer and with a tubular K-member i would have alot more room to run my piping.
but there are really no adverse affects other than the install and unless i get the roadrace option it is too weak for everyday driving?K&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
I personally would not put even the road race version on my car. The stock K is stronger than any of the tubular aftermarket versions and for me a K-member is a terible place to make things weaker. It is up to you though and if reducing weight is what you are after the K will lower your weight more than pretty much any single other part. I would recomend getting tubular upper a-arms and the G2 lower a-arms instead if you want to lower weight. As for the turbo piping i understand because i had looked into this for my turbo system but decided that strength was more important. Look at the incon kit if you want to look into other ways to rout the piping without going under the K.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
The K-member would definitely open up lots of space for what you are planning, definitely go for it.
by PettrrHey all,
I know this is a Camaro forum first and foremost (mine's a ‘00 V6), but I figured I'd ask — does anyone here also mess around...15 hours ago -
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 week ago
