I think to get toward the 1st place position i need help with suspension. Right now all i have is BMR Tubular Control Arms Poly/Poly bushings and BMR Tubular Non adjustable panhard pard Poly/Poly bushings. With that setup and no front sway bar i rin 14.345 @92.55 with a 1.866 60 foot anything that yall recommend me getting that will help me get better ET's
[ December 08, 2002: Message edited by: slacker69 ]</p>
<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
He wants to know what he can do for his suspension to lower ET's.
I've heard Subframes help a little bit on launches, then again they add weight so it could even out in the end. But man do they look cool and help you turn like a sonafa*****. :D
I guess the only other thing you could do is a torque arm but they are pricey.
[ December 08, 2002: Message edited by: Redsix ]</p>
<b>Red 1999 Firebird M5</b><br />Whisper Lid,Borla Catback,K&N,Dual Friction Center Force Clutch,Hurst Shifter w/Lou\'s Short Stick,!FRA,Suncoast Ramair hood,160 Thermo,!maf,Chrome ZO6 Wheels, Painted Calipers, CIA Headers, Taylor Wires, NGK Spark Plugs, 3\" Catco, Jet Chip Stage II, BMR STB, LCA, PHR, SFC, Fan Switch, FTRA<br /><b>Old Dyno Numbers: 183 RWHP, 217 RWTRQ</b><br /><a href=\"http://community.webshots.com/user/redsixer\" target=\"_blank\">http://community.webshots.com/user/redsixer</a>
Couldnt care if my car turns hell without a front sway bar and skinnys its not exzactly a turnin beast
BMR Xtreme rear swaybar, or at least a 1Le bar w/ poly bushings/endlinks. when I did this, I noticed better traction off the line, and no rear twist like before. it'll squat evenly, placing force on both rear tires. after that, torque arm and sfc's.
I run:
no front sway bar
Mild steel light weight lower a arms
Mild steel drag light weight k member
skinnies
no strut tower brace
poly torque arm mount
poly tranny mount
hotchkis boxed trailing arms
hotchkis pan hard rod
rk sport tubular sub frames
stock shocks
sotck springs
I have not messed with torque arms but I'm told that this is something I really need to do this winter so I'll update when I get there.
I also plan on getting the upper mild steel light weight a arms
Maybe at some point I'll upgrade the rear sway bar
My mid 11 second ls1 people swear by Hal shocks!!!
One consistently pulls the tires off the ground 6-12 inches!!!
3 days ago
