Okay when I stomp the gas decently hard, I get a loud clunk and I feel it in the front end, actually feels like its the front passanger side. Only happens on gas hits from stops forward, or almost any time I put it into reverse and give it a bit. I can feel it pretty badly. I am not a king of suspension knowledge, and havn't gotten a time to take a good look at it. Any ideas what I have to replace here?
Loud front end Clunk!
i had a brand new front strut that got locked down some how. Basicly when the spring pushed the car back up it ripped the stut from its rubber mount. An easy way to tell is go above the drives and passanger side tires and push down on the body like your trying to make it jump up and down. If one side moves much easyer then the other, and or has the clunk, thats your problem.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
