Looking to upgrade my stock suspension for better handling around turns and coners and also looking to get a better "jump" of the line. What would I need to do first and what are some good brands to go with?
suspension help please
Most of the vendors have similar products. Look at UMI Performance, good price and good service. For turning performance you won't go wrong with some LCAs, a panhard, and a nice torque arm.
g2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
The relocation bracket really makes a difference, just make sure u get the weld on so you don't have to worry about maintaining it over time.
I ordered it from tsp, along with bmr lower control arms. As far as a difference between aftermarket brands, i don't think there is a difference, just how much they weight and look.
v8 take offs are cheap like the sway bars, much better than stock v6, much thicker. I don't know if aftermarket front/rear swaybars are better or just as good as the 32/19 v8's have.
I no longer swing my rear out while taking a turn under wot. Launches great and i can take turns much faster now. I used to have a loose rear end, had to lay off the pedal then floor it again to keep straight.
What I upgraded for chasis/suspension:
Hotchkis Strut Tower Brace
Hotchkis Sub Frame Connecters
BMR Relocation Bracket Weld-on
BMR Lower Control Arms (Tubular)
WS6 take off Front/Rear Sway Bars
WS6 take off Driveshaft
WS6 take off Springs (Most don't do this, but i prefer the car being a little higher, not a fan of low rider types)
Polyurethane trans mount, no vibrations, no complaints from it.1998 Rally Red Camaro
Manual 5, T-Tops
Ebony Leather Interior, Kicker Audio System
