So what kit can i buy to bleed my brakes easy? Also what is the best way to do it. And do they make a kit that bleeds all 4 at once? Iam new at this. Iam getting tried of paying $30 to get it done! Thanks and please post links!
Whats the best one man brake bleeder kit?
2001 Sunset orange Firebird! Gone!<br /> <a href=\"http://www.cardomain.com/memberpage/478082\" target=\"_blank\">http://www.cardomain.com/memberpage/478082</a> <br />Whisper lid,SLP CIA,FLowmasterexhaust.Tags: None
Your local auto parts store(s) should have self bleeding kits for around $15. You'll need to bleed one wheel at a time in this order;
rear passenger tire, then rear driver's side, front passenger, then finally the front driver's side.
How many times are you getting this done per year? There may be a bigger problem you'll need to take care of first before buying a bleeder kit.
-Marcsigpic
Russell Speed Bleeders make things a WHOLE lot easier.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
viper98885: By the way, I think you have the wrong part numbers (at least for a '96) on ammp.
The front calipers are, at least on a '96, (checked both stock, and reman unit from autozone, and the factory parts manual) were 10mm X 1.5 Which would make the fronts 639580.
Haven't delt with the rears.<a href=\"http://www.fatninjas.com/camaro\" target=\"_blank\">\'96 Camaro Convertible</a>
<blockquote>quote:</font><hr>Originally posted by BillyCobin:
Haven't delt with the rears.<hr></blockquote>
Follow this link and check out Russell's application page. That is what I use for the part numbers. Also, I used these part numbers when I ordered them for my car and they worked fine.
Russell Performance Speed Bleeder Applications - Chevy- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
<blockquote>quote:</font><hr>Originally posted by hockeyman:
-Marc[/QB]<hr></blockquote>
Not two many. Just i have more then one car i do brakes on and other stuff. Plus my car has a caliper problem that was causeing the brake problem. But the dealers where being a holes. And wouldnt fix it. So they keep saying it was air in the lines and the brake bleeding started adding up. Plus iam planing on getting new rotors and better calipers. So i wanted a kit to bleed them. Thanks for the help!2001 Sunset orange Firebird! Gone!<br /> <a href=\"http://www.cardomain.com/memberpage/478082\" target=\"_blank\">http://www.cardomain.com/memberpage/478082</a> <br />Whisper lid,SLP CIA,FLowmasterexhaust.
Try this link: Motive Products.2001 Camaro M5 Coupe(1 of 2,737), no options, Whisper Lid, K&N Air Filter, Free Ram Air, MAFS Screen removed, SLP Manual Fan Switch, 160 thermo, DEE\'s T/B Spacer, EGR Block-off plate, IAT resistor, CAI to EGR air feed, B&M Ripper Shifter, SLP Replacement Grill, T/A Exhaust, SLP five spoke take-off wheels, BMR strut-tower brace, BMR Tunnel Brace, BMR 32/21 front & rear sway bars with poly, BMR Poly/Combo Rear Control Arms, Clear front & rear corners, HPP3 modified 87 Octane program.<p><a href=\"http://www.cardomain.com/id/red2k1\" target=\"_blank\">http://www.cardomain.com/id/red2k1</a>
Sorry to disrupt the thread again.
viper98885: I tried putting the 639560s into the stock calipers on my 1996 camaro convertible's front calipers, and they did not fit. I tried putting them into reman units from autozone, they did not fit. They were the right width, just the wrong thread pitch. I looked them up in a pdf parts file, and it said 10X1.5 for 94-97 front calipers. I took a screen shot, it's a little blurry because of the compression. I can make a bigger one if needed.
There must be more than one version of the front calipers out there.
http://www.fatninjas.com/misc/bleeder-screenshot.jpg
I don't want to make you mad or anything, I got my headers from ya and am very pleased, just wanted to alert you to what I had found.
[ October 28, 2003: Message edited by: BillyCobin ]</p><a href=\"http://www.fatninjas.com/camaro\" target=\"_blank\">\'96 Camaro Convertible</a>
