Rear brakes on 3rd gen... didnt know where to turn
On my 82 trans am, it came with a 10bolt 3.42 posi drum rear end.. Im currently in the project of swapping in a 85 iroc 10bolt 3.42 disk rear end in the car. My question is, what exactly will i need when i start hooking the brakes up? All i have is the adapter plates on the rear end, i will need to buy calipers, rotors, and brake lines.. What about the bolts that hold on the calipers tho, im not sure what or where to get those yet. The car is a 5spd manual, so ebrake would be nice too. The car is a autox car if that makes any difference, but all stock parts are good for now unless aftermarket is cheaper. Thanks
Ric
Ric Johnson<br />----------------<br />1995 Pro AM III #12<br />3.4 A4<br />KN FIPK intake with ram air mod<br />Flowmaster exhaust<br />RKSport IAT sensor <br />ASP Underdrive pullys<br />TB Bypass<br />PF52 larger oil filter<br />3.42 non posi rear end<br />DeCarbon Trans Am shocks<br />Eibach pro series springs<br />B&M Shift Plus+ (best $40 ive ever spent)<br />Custom made billet alum front end inserts<br />Interior trim painted to match the car<br />Awia CD player with factory bose sound system<br />Viper alarm system<br /><a href=\"http://www.proam.webhop.org/\" target=\"_blank\">http://www.proam.webhop.org/</a>
3 days ago
