my abs light wont go off how do i fix it?
abs light
Check your collision light. ABS light goes on when this light burns out.
If not, take it to a shop and have it scanned.Matt
1998 Mystic Teal Camaro M5
^ yes if you changed your carrier or gears and did not replace the abs reluctor ring it will make that light come on..i fixed this by taking out the cluster and pulling out the little LED :D<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
no now instead of the tires chirping left and right they just lock up. all the gears are stock i did nothing. i did a hard lauch when i was whooping a celica and after that it wont go off and my brakes lock up and slide so i cant drive in the rain until i get it fixedcant wait till my lt1 and nitrous.
