i bought a energy suspension trans mount, and i was wonder what modifacation i would need to modify my cross member to fit it, but im not sure if i should, and what kind of modifacation i will need to do. any help i can get would be great, thanks.
poly urethane trans mount
the hole on the cross member that allows access to the nut that holds on the tranny mount might need to be widened a bit..personally i can get to mine without having to do that..but some people do..i also had to use a washer just before the nut goes on..its a great mount and i've never had any trouble with it<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
The enegry suspensions transmission mount is approximately .5" shorter than your stock one. I would recommend adding a shim of some sort to get the transmission to the original height. Otherwise you will put your pinion gear at a bad angle and possibly cause your rear end to wear prematurely.
Most people do end up having to elongate the hole in the crossmember in order to get the new tranny mount to fit. It's really not too hard tho. I just dremeled mine out.1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
Just did mine yesterday,
Yes, you have to get a new hole for the bolt
tried 2 ways
1st ES mount only - horrible noise/vibration. Had it for a week - same. + at least 1" trans drop - no good.
2nd instead of shims I used stabilizator robber rings on 2 transmission bolts (4 total) No more vibration, trans back to the stock level,much firmer than stock mount
