Sticky brake piston question.. - FirebirdV6.com/CamaroV6.com Message Board
  • Sticky brake piston question..
    OK--had a buddy of mine replace my front rotors/pads today. When he removed the old pads and tried to compress one of the pistons on the right side, he had a pretty tough time. We sprayed on quite a bit of brake cleaner on both pistons and reinstalled it. The brakes seem to work fine. I've got a 2000 V6. Is this something I should worry about??
    --chris--
    Anyone??
    --chris--
      If you got it loose you shuld be fine.. be sure to grease it if you have not allready done so..
      break piston grease
      ~Bill
        1997, I just replaced my rear left, was locked and couldnt get it lose, commmin - usually unknown problem.
        97 Special Edition Bird , Short bus stlye special
