The bmr site has a writeup with ramps, but alls i got at home is a jack and 4 stands, does the suspension need to be loaded to put in my new sways? im doing front and rear... please help quick so i cna buy ramps if needed, i want to do this TONIGHT!!!
*singing*.....tonight is the night....whooo-oo--aaa! .....*singing*
-Hawk<br /><br />===================================<br />Black 2001 Pontiac Firebird<br />Automatic Transmission Street Bird<br /><br /> <a href=\"http://www.cardomain.com/memberpage/550453\" target=\"_blank\">http://www.cardomain.com/memberpage/550453</a> <br /><br />\"Live like you were Dying\"
If it helps, I did the front sway bar this weekend using ramps and felt jack stands would have been easier. Ran into a slight issue removing the endlinks because the ramps were in the way, had to use the jack to bump the car up an inch or 2 to get the endlinks out.
BTW, the bolts were 1/2 inch not 13mm like I expected. Rounded one of the bolts on the bushing before I figured it out.
The middle part of the endlink will stick trying to get it out if the suspension is loaded (least it did for me) but I doubt there is some technical reason not to do it with jack stands.
Was a pretty easy install, if I hadn't misplaced my breaker bar it would have only taken 30 minutes.
hmmm i guess ill just use jack stands then... i hope i can still do it lol... otherwise im going to be angry at you Wacko!!! haha, notice any difference? what brand/size did u go with?
thanks
Went with the 1LE 32mm front and the poly endlinks/bushings from Thunder Racing, rear is still the stock 17mm. Seems to corner better, little less body roll but it seems to be more prone to fishtailing. I only drive the car every month or 2 though so this could all be my imagination.
FYI the bolts on the bushings were completely frozen for me, I had to use a 2 foot breaker and put all my weight into it to get them loose.
well i installed both of them in about an hour. (breaks included) fun stuff, not incredibly hard and i didnt run into many problems... im afraid that the endlinks might not have been tightened enough though, and i dont have a torque wrench to tighten them down to specs... so im kinda worried...
i think that ill just buy one today and then tonight ill jack it up into the air and illtighten them down to specs... that will make me feel better... i didnt have loctite either :( oh well im sure itll be fine at least for one day
Its alot easier to line up and get them torqued down right when the wheels are off.
Jack it up really high on the K-member, and put the jacks under the lower control arms and bring it down slowly.
Depending on your jack may not be able to jack it high enough.
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...
