What are your thoughts on these tires. - FirebirdV6.com/CamaroV6.com Message Board
  • What are your thoughts on these tires.
    Ok i've had a set of Sumitomo HTR+s 245/45/ZR17 or something for about a year. And all of them are worn really badly and 2 of them have belts showing through. My vehicle is properly aligned and the tires are properly balanced. It's really disgusting because I paid around $500 bucks for a set of tires that didn't even last a year. So now I just want to replace the rear 2 because of the belts. So I am not looking for a performance tire but a tire that will last a long time. I'm going to be going through tirerack because of where I work I can get a really sweet discount.
    http://www.tirerack.com/tires/tires....omCompare1=yes
    BFGoodrich Traction T/A/H
    245/45HR17
    The speed rating isn't Z like the tires I have now I think the H is like 128 or something? So it should be a lot better treadwear. I wanted to bump the sidewalls up to 50 or 55 to get rid of the gap in the back but i think I can only buy them in 45.
    There isn't too much better tires out there that I saw with a good traction rating. My price is around 130 or so per tire.
    Tell me what you think
    What you want to do is look at the treadwear rating on the tire(s). Anything lower than 200 will give you exceptional traction, but wear out extremely fast. Anything between 250-320 is decent traction, and average treadwear. Anything over 400 is like having concrete tires. They will give $hitty traction, but probably last the lifetime of your car ;)
    -Marc
      good luck on getting any actual type of answer no one ever really tends to answer when you really need them ive had 2 topics go unaswered. the best i can tell you is the goodwrench
        Tell me about it 2000v6bird. I've been on the board for a few years now. about 75% of my posts go unanswered. And to get an idea of how I post if the post counter was still on i'm sure it'd be around 3000. By the time it takes someone to help me out, i've already found some sort of solution though so it's cool.
          Ok, well since tirerack didn't post the treadwear rating, I think you should ditch the BFG's, and go for the Kumho 711 or 712's. You'll get a better "Bang For Your Buck", the treadwear is 280 on the 712's, and they are excellent wet-traction tires.
          -Marc
            The specs are listed right there. All the rating informatoin your looking for.
            http://www.tirerack.com/tires/Spec.j...action+T%2FA+H
            my tire suggestion is this:
            http://www.tirerack.com/tires/tires.jsp? tireMake=Yokohama&tireModel=AVS+ES100&vehicleSearc h=false&partnum=445WR7ES100&fromCompare1=yes
            [ November 07, 2003: Message edited by: Blazzin Joe ]</p>
            2002 Maple Red Firebird V6<br />3.73 w/ LSD | Pro-5.0 Shifter | Fan Switch | Tach w/ Shiftlite | Boost and Fuel Pressure Gauge | Bilstein Shocks & 1LE Springs | 1LE 32mm Bar & Poly Bushings, Poly Tranny Mount and Torque Arm Bushing | BMR LCA\'s | Catco 3\" Cat w/ Edlebrock 5509 Muffler, (all 3\") | Corbeau A4 Seats (Pair) |<p><a href=\"http://forums.fakeleg.com/\" target=\"_blank\">http://forums.fakeleg.com</a><br /><a href=\"http://cv6.fakeleg.com/\" target=\"_blank\">http://cv6.fakeleg.com</a> - Part & Repair Manuals and write-ups.
              I'm with Blazzin' Joe, Yokohama AVS ES100 IMO is the best for traction and treadwear. It's ranked 4th best overall by consumers like me ;) (TIRERACK survey). I used to have stock Eagle GAs and switched to Kumho 712s then UPGRADED to YOKOs. The difference is literally night and day. The Yokos I've got is 250s but its wider than Kumhos 712s with the same tire width. It costed me 360 bones with all 4 tires, tax included, I think its only 10 bucks more than Kumhos.
              <i>00\' NBM Firebird~T-5<br />60\': <b>2.29 sec.</b><br />1/4: <b>14.7 @ 95.5 MPH<br />Ask not what your country can do for you, ask what you can do for me.</b></i>
                <blockquote>quote:</font><hr>Originally posted by Ted:
                And to get an idea of how I post if the post counter was still on i'm sure it'd be around 3000.<hr></blockquote>
                Or 1461 [img]graemlins/stickpoke.gif[/img] :D
                [ November 11, 2003: Message edited by: 98Camaro3.8 ]</p>
                Matt
                1998 Mystic Teal Camaro M5
                  I've been really happy with my Yokohama AVS ES100's. I'm running the P245/50ZR16's on my Camaro now. They're rated traction AA, temperature A, with a treadwear rating of 240 or so.
                  2001 Onyx Black Camaro M5-Totalled<br />2005 Ford F150 XLT 5.4L<br /><br />\"To make peace, prepare for war.\"
