I was wondering if the LS1 rotors and pads are interchangable with my 98 v6? I can always find performance pads and rotors for LS1 cars but not for v6 specific. So will they fit? Also what pads and rotors would you recommend? My rotors are warped bad. I need info ASAP.
I believe the breaks are the same regardless of engine. So you should have the same breaks as a 98 LS1. 98+ rotors are thin and warp. Get aftermarket rotors like Bear or Wildwood or KVR.
3 days ago
